on 12-04-2024 06:12 PM
People on the other end of VOIP calls (MS Teams, WhatsApp, etc.) often complaint that my voice keeps breaking up or lags.
It shows me on the router that I have an uplink of 14 Mbps but, the issue persists.
Also, when I try to do any line or other test using the TalkTalk portal, it keeps saying go to your Eero which is strange as I haven't been given an Eero. I have the regular black WIFI router.
What could be wrong?
Tuesday
Thanks, but you don't have a VoIP service do you?
Tuesday
Yes, Chris!
Tuesday
Hi CorleoneUK,
Just to confirm, is that from the router settings?
Tuesday
Yes, received the router and have set it up. Also, an Openreach engineer had come to take a look at the line and he said TalkTalk had changed some settings which was affecting the line stability. He has reset it and since then the line is stable with decent speed.
But, I think my phone line is disabled.
This is what it shows me on the new router which I'm sure wasn't the case earlier. Any thoughts?
Tuesday
Hi CorleoneUK
I'm really sorry for the delay.
Have you received the router since your last post?
on 03-05-2024 02:47 PM
Hi Michelle,
The line has dropped twice today and it's currently working at a pathetic speed if at all you call this working
on 03-05-2024 01:44 PM
Not yet!
on 03-05-2024 08:47 AM
Has the router arrived?
on 01-05-2024 06:39 AM
Hi CorleoneUK
I can't see the tracking number yet. You should also receive a text message with the delivery notification.
on 30-04-2024 06:24 PM
Can you share a tracking number, please?
on 30-04-2024 08:25 AM
Hi CorleoneUK
on 30-04-2024 08:17 AM
Yes, please!
Thanks Michelle.
on 30-04-2024 07:01 AM
I'm sorry to hear this. I've re-run the line test now which is clear, however I can still see re-connections on the line. Would you like us to send a replacement router to see how this compares and to rule this out?
on 29-04-2024 11:28 PM
5, 6 line disconnects and counting...
on 29-04-2024 10:18 PM
The line restarted the third time in the last one hour. The router's log shows this:
Please help resolve this issue.
on 29-04-2024 09:53 PM
It was seeming to be a bit better. But, now I my line disconnected several times and so I ran the line test this is where I ended.
Not sure what to do now.
on 26-04-2024 07:13 AM
I'm sorry to hear this. Would you like us to send a replacement router for testing purposes to rule this out?
on 25-04-2024 02:56 PM
I guess MS Teams calls are fine now but, I think WhatsApp voice calls are still a problem.
Not sure what could be wrong.
on 17-04-2024 07:09 AM
OK thanks
on 16-04-2024 10:37 PM
Restarted the router after 30 mins. I'll keep testing and report back.
