Light settings on WIFI Hub
Deanosafc24
Message 8 of 8
How do I turn on/off the light on my WiFi hub, I get to WiFi hub settings through 192.168.1.1 then I logs out
7 REPLIES 7
Message 1 of 8
Morning @Deanosafc24
Do you still need assistance with this?
Message 2 of 8
Message 3 of 8
Hi Deanosafc24
Have you also tried this in a different browser?
If you have tried this then we may need to send you a replacement router.
Message 4 of 8
That’s what I am doing, but I get to the WIFI Hub icon then it logs out and have to start again.
Message 5 of 8
Hi Dean,
Ok thanks. Could you try the below please.
  1. WI-FI HUB BLACK
    Open your browser and type 192.168.1.1 in the address bar to go to the router admin page
    Login with your router username and password. You’ll find these on the sticker underneath the removable settings card on back of your Wi-Fi Hub
    Select See Internet Settings
    Select Manage Advanced Settings
    Select the TalkTalk Wi-Fi Hub icon at the top of the page
    Select Light Control
    Select the ON button to toggle it on or off and then choose Apply
Message 6 of 8
The Black
Message 7 of 8
Hi Dean,
Have you tried resetting the router and trying this again? Do you have the Wifi Hub or the Wifi Hub Black please?
