WiFi extender
AdieB2
Sightseer
Message 7 of 7
Could someone advise what type of wifi extender I would need for use with Eero Full Fibre hub please. I have installed a Ring doorbell and the wifi signal is weak and needs extending.
6 REPLIES 6
Message 1 of 7
Hi AdieB2
Thank you. I'm just sending you a Private Message.
Message 2 of 7
Hi Debbie, I think I have done it successfully!
Message 3 of 7
Hi AdieB2
Please can you add your name and TalkTalk account number to your Community Profile, we can then take a look at this for you.
Thanks again.
Message 4 of 7
Hi Debbie, yes just one Eero
Message 5 of 7
Divsec
Message 6 of 7
Hi @AdieB2 I'm thinking another Eero would be your best bet. Unfortunately I don't have any experience with either so cannot be sure.
