YouView TV Guide not working or slow
Message 49 of 49
@Mmatt , @Pez30 , @Bferen , @Frankafrank , @Rusty_2 , @Glendevonfrank , @Glenda5 , @Cathcol , @SCBierton13 , @Suezz , @Chevy1
Can you all please confirm if you have tried the following :
removing the aerial  = Y/N
remove the ethernet = Y/N
reboot = Y/N
retune = Y/N
Also have you done a factory reset Y/N
If you can also let me know the number of channels you have after a reune, and if you notice this issue affecting a specific channel, or what channel you are watching when you notice this happening.
Please reply just in this thread so I can collate all answers for our Youview contacts.  I'm in direct contact with them currently so can relay info across quickly.
I'll also pin this thread at the top for now so it's easy for you all to find.
48 REPLIES 48
Message 1 of 49
The issue affecting the guide has been resolved.  This was caused by an external factor that has now been resolved by the vendor.
Message 2 of 49
The issue affecting the guide has been resolved.  This was caused by an external factor that has now been resolved.
Message 3 of 49
Message 4 of 49
This issue has now been resolved and the signal issue that was triggering this has been corrected.
Rusty_2
Message 5 of 49
Appears to be working at present- fingers crossed
Rusty_2
Rusty2
Supermole
Sightseer
Message 6 of 49
It appears to be working now, fingers crossed.
Message 7 of 49
Working OK again.  Problem seems to be fixed. Thank you for your help.
Message 8 of 49
Mine seems to be ok as well, but this happened yesterday & then went AWOL.
Annie
Suezz
Sightseer
Message 9 of 49
Seems to be working but then it has worked for a while then gone of again before. My fingers are crossed yet again. A friend who also has a youview box says hers is not working properly so I don't think it's fixed !.
Message 10 of 49
I can change channel and see the guide now but certain channels are really bad reception which I never used to have pre this issue
Message 11 of 49
A couple of people on another thread are saying their boxes are now working.
Can you please check your boxes and confirm all is now okay, or if course if it's not.
Thank you
Message 12 of 49
7 hrs ago I spoke too soon!!!!! NOT back to normal- Guide got no data again & whilst some progs recorded this morning ok - just tried recording  a live program & not happened -
is this going to get fixed I wonder?
Annie
Message 13 of 49
Question?
Are the boxes still recording programmes you have set up?
If so, a suggestion that in the meantime,
  • you let the box record programmes and use it only for playing back (or won't the remote allow you to select MyTV)
  • use your TV tuner to watch normal TV(assuming it have a Freeview tuner).
Message 14 of 49
Everything seems to be back to normal, for now anyway!!
thanks for the info 👍
Annie
Message 15 of 49
Didn’t last long at all 😩 Back to slow/ no response. It time for a phone call to cancel for breach of contact.
Message 16 of 49
This seemed to have worked for me. Don’t know how long it will last though.        One thing to test, take out the aerial, then select BBC1 (channel 1) on the box/remote.
When the box changes to channel 1, plug the aerial back in and see if the small EPG (Guide) shows ok at the bottom of the screen.
Try changing to 101 (BBC HD) and see if that is responsive.
Then try Channel 236 - GBNews and channel 233 Sky News and see if they are showing ok and are responsive and that the EPG is loading and showing ok.
Thanks Karl
Message 17 of 49
It’s gone again frustrated is an understatement.
Message 18 of 49
@Annie9896 Karl is not back now until after the weekend.
Yo answer your question, no it does not record and you have to phone if you are interested in getting one. You may also need to recontract.
If they suggest you have to return your recordable box, stress the reason you want a box is ITVX and that you want to retain your box to record programmes that are not on a catch-up apps.
Try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
Message 19 of 49
I have done that worked ok after a reboot.  Currently able to use all channels and remote/guide seems ok too 🤞 it stays that way
Message 20 of 49
Thanks Karl. Does the new TVHUB have a RECORD facility ?
Annie
