on 20-04-2024 04:46 PM
I'm having issue with my Sagemcom Fast 5364 wifi hub, version: SG4K100174. I keep manually changing my 2.4ghz and 5ghz wifi channels but after a while it randomly reverts back. The channel it reverts to is heavily congested which causes my wifi devices have a weak wifi signal.
Needing to constantly change the wifi channel is annoying so I've spoke to TalkTalk support on live chat who have asked me to factory reset my wifi hub but I'm still having issues.
Looking at the forum, it looks like I might need TalkTalk forum support to disable wifi optimisation for my account.
2 hours ago
Good morning,
Have our team contacted you since our last post?
Monday
Hi Gigabytes517
I'm so sorry to hear this.
I've just let our faults escalation team know and asked them to contact you as soon as possible.
Monday
I setup the talktalk wifi hub 2 on Saturday and left the configuration on auto channel for 2.4ghz and 5ghz.
However I later noticed low signal loss and and using the wifi analyzer app saw that on 2.4ghz it was using channel 6 which is heavily congested in my area so I manually changed it to channel 9 and on 5ghz it was using channel 40 which is also heavily congested so I changed it to channel 64.
Since then the issue reoccurred again with 5ghz going to channel 36 which is also heavily congested. How can I configure the wifi hub to not randomly change the wifi channel? If I manually set the channel, it should respect the setting and not randomly change it to a worse one.
Monday
How are you getting on?
on 10-05-2024 07:31 AM
Have you received the router or received a notification for the router delivery?
on 08-05-2024 11:53 AM
Hi Gigabytes517
Please let us know if the new router resolves this issue.
on 08-05-2024 11:48 AM
Yep, they told me they will be sending a new wifi hub.
on 08-05-2024 11:40 AM
Can I just check, have you spoken to our faults escalation team today?
on 07-05-2024 07:00 AM
Hi Gigabytes517
Apologies. We can't switch this off now.
I've asked our faults escalations team to take a look at this for you. They will also contact you to discuss this further.
on 04-05-2024 02:46 PM
My 5ghz WiFi channel has reverted back again. As asked previously, please can you turn off WiFi optimization for my account.
03-05-2024 01:54 PM - edited 03-05-2024 01:59 PM
Hi Gigabytes517
Our faults escalations team are now investigating this issue and they may contact you directly to discuss this further.
on 30-04-2024 01:03 PM
Hi Gigabytes517
I have asked our Devices Team to take a look at this for you and I will post back as soon as I have further information.
on 30-04-2024 12:03 PM
Hello @Debbie-TalkTalk, since restarting my wifi my 5ghz channel has remained on the channel I selected, my 2.4ghz channel reverted back channel 1 which is heavily congested so I changed it a more quiet channel just now. I will report back it if either of channels randomly change.
Please can you confirm that Wifi Optimisation has been turned off on my account?
on 30-04-2024 11:44 AM
Do you still need help with this?
on 24-04-2024 07:45 AM
on 22-04-2024 07:25 AM
Hi Gigabytes517
Please can you reboot the router and the retest again?
20-04-2024 05:17 PM - edited 20-04-2024 05:18 PM
Staff will sort this after the weekend, @Gigabytes517.
Make sure that you have left the router switched on for when they come in, early Monday morning.
